Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 16
Recognizing & Disconnecting Cable Connectors, Soldered Connections: Schritt 0, Bild 1 von 2 Recognizing & Disconnecting Cable Connectors, Soldered Connections: Schritt 0, Bild 2 von 2
  • You may encounter wires that weren’t designed to be removed at all, and are soldered in place.
  • Not to worry! A soldering iron makes quick work of these little guys.
  • If you don't have any soldering experience, head on over to our soldering technique guide or check out our soldering 101 blog post and video.
또한 아예 분리하지 못하도록 설계된 전선은 실제로 납땜되어 있습니다.
걱정하지 마세요—납땜 인두와 약간의 납땜 심지는 이 작은 녀석들에 신속한 작업할을 가능하게 합니다.
아직 납땜에 익숙하지 않은 경우 자사의 납땜 기술 안내서로 이동하여 새로운 기술을 배우세요!
[title] Soldered Connections
-[* black] You'll also encounter wires that weren’t designed to be removed at all, and are in fact soldered into place.
-[* black] Not to worry—a soldering iron and some soldering wick makes quick work of these little guys.
-[* black] If soldering isn’t yet your thing, head on over to our [guide|750|soldering technique guide|new_window=true] and learn a new skill!
+[* icon_note] You may encounter wires that weren’t designed to be removed at all, and are soldered in place.
+[* black] Not to worry! A [product|IF145-781-1|soldering iron|new_window=true] makes quick work of these little guys.
+ [* icon_note] If you don't have any soldering experience, head on over to our [guide|750|soldering technique guide|new_window=true] or check out our soldering 101 [link|https://www.ifixit.com/News/6864/how-to-solder|blog post|new_window=true] and [link|https://www.youtube.com/watch?v=rK38rpUy568|video|new_window=true].
