Zum Hauptinhalt wechseln
Nintendo 3DS 후면 커버 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 25 Anleitungen, die diese beinhalten.
Schritt 2 übersetzen
Englisch
Koreanisch
Schritt 2
Nintendo 3DS Back Cover Replacement, Remove the rear cover: Schritt 0, Bild 1 von 2 Nintendo 3DS Back Cover Replacement, Remove the rear cover: Schritt 0, Bild 2 von 2
  • Hold the device in one hand and turn it over.
  • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
  • Flip the 3DS over again so that the back cover is facing up.
  • Pull the back cover up and away from the rest of the device to remove it.
3DS를 뒤집고 진행합니다.
후면 커버가 다시 제자리로 돌아가지 않도록 반대쪽 손으로 후면 커버의 상단 가장자리를 잡으세요.
3DS의 후면 커버가 위를 향하도록 다시 뒤집으세요.
후면 커버를 위로 당겨 기기의 나머지 부분과 떨어뜨려 분리하세요.
+[title] Remove the rear cover
[* icon_note] Hold the device in one hand and turn it over.
[* black] Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
[* icon_note] Flip the 3DS over again so that the back cover is facing up.
[* black] Pull the back cover up and away from the rest of the device to remove it.
