Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 25 Anleitungen, die diese beinhalten.
Schritt 1 übersetzen
Schritt 1
Loosen the rear screws
Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
- | [* red] Unscrew the four Phillips #00 screws along the top of the back cover. |
+ | [title] Loosen the rear screws |
+ | [* red] Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover. |
+ | [* icon_note] All screws in this device are [guide|93991|JIS screws|stepid=176809|new_window=true]. Official [product|IF145-006|iFixit PH000-PH1 Phillips screwdrivers|new_window=true] are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in [guide|13213|stripped screws|new_window=true]. |
[* icon_note] The screws are held in place by locking washers, and will not come out of the back cover. | |
- | [* icon_caution] The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow. |
