Zum Hauptinhalt wechseln
4Sight 9 Screen Replacement
Was du brauchst
    1. 4Sight 9 Screen Replacement, Cover: Schritt 1, Bild 1 von 2 4Sight 9 Screen Replacement, Cover: Schritt 1, Bild 2 von 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. 4Sight 9 Screen Replacement: Schritt 2, Bild 1 von 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Frag FixBot
    3. 4Sight 9 Screen Replacement: Schritt 3, Bild 1 von 2 4Sight 9 Screen Replacement: Schritt 3, Bild 2 von 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Frag FixBot
    1. 4Sight 9 Screen Replacement, Battery: Schritt 4, Bild 1 von 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Frag FixBot
    2. 4Sight 9 Screen Replacement: Schritt 5, Bild 1 von 2 4Sight 9 Screen Replacement: Schritt 5, Bild 2 von 2
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      Frag FixBot
    1. 4Sight 9 Screen Replacement, Screen: Schritt 6, Bild 1 von 2 4Sight 9 Screen Replacement, Screen: Schritt 6, Bild 2 von 2
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      Frag FixBot
    2. 4Sight 9 Screen Replacement: Schritt 7, Bild 1 von 2 4Sight 9 Screen Replacement: Schritt 7, Bild 2 von 2
      • Remove the second electrical ribbon from the motherboard using the same technique used to remove first ribbon.
      Frag FixBot
    3. 4Sight 9 Screen Replacement: Schritt 8, Bild 1 von 1
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      Frag FixBot
    4. 4Sight 9 Screen Replacement: Schritt 9, Bild 1 von 2 4Sight 9 Screen Replacement: Schritt 9, Bild 2 von 2
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      Frag FixBot
    5. 4Sight 9 Screen Replacement: Schritt 10, Bild 1 von 2 4Sight 9 Screen Replacement: Schritt 10, Bild 2 von 2
      • With the motherboard facing you, look to the bottom left corner, pull on the camera to completely free the motherboard.
      Frag FixBot
    6. 4Sight 9 Screen Replacement: Schritt 11, Bild 1 von 1
      • Using your fingers, gently lift the motherboard and battery.
      Frag FixBot
    7. 4Sight 9 Screen Replacement: Schritt 12, Bild 1 von 3 4Sight 9 Screen Replacement: Schritt 12, Bild 2 von 3 4Sight 9 Screen Replacement: Schritt 12, Bild 3 von 3
      • Insert plastic prying tool under screen and exert pressure, pulling upward.
      • Repeat this step around each corner of the screen until it pops off.
      • Ensure screen is free from all black tabs holding it in place.
      Frag FixBot
    8. 4Sight 9 Screen Replacement: Schritt 13, Bild 1 von 1
      • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes
      • Remove plastic film from glass frame
      Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 3,422
