Zum Hauptinhalt wechseln
ACER Aspire E1-572-6870 Battery Replacement
Was du brauchst
  1. ACER Aspire E1-572-6870 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Battery Replacement: Schritt 2, Bild 1 von 3 ACER Aspire E1-572-6870 Battery Replacement: Schritt 2, Bild 2 von 3 ACER Aspire E1-572-6870 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cody Lim
1.404 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 9-6, Banghart Winter 2017 Mitglied von Cal Poly, Team 9-6, Banghart Winter 2017
CPSU-BANGHART-W17S9G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 76
Insgesamt: 5,922
