Einleitung
Use this guide to learn how to take out or replace your battery.
Was du brauchst
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Slide the lock switch to the right using your finger or a spudger.
At the same time, grasp the battery with your other hand and slide it out of the laptop.
Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 weitere Personen haben diese Anleitung absolviert.
