Einleitung
Follow this guide to remove the back cover on your ASUS TUF Gaming F15 FX506L. This procedure gains you access to all of the device internals, allowing for repair or replacement of any component.
Was du brauchst
Use a Phillips screwdriver to remove the 10 screws securing the back cover:
Seven 11.6 mm screws
Two 14.6 mm screws
One 6 mm screw
Use a Phillips screwdriver to loosen the captive screw.
Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
Pry up to release the clips securing the back cover.
Insert your opening pick again between the top-left corner of the back cover and the chassis.
Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
