Zum Hauptinhalt wechseln
Accessing Logicboard
Was du brauchst
  1. Accessing Logicboard, Front and Back Cover: Schritt 1, Bild 1 von 2 Accessing Logicboard, Front and Back Cover: Schritt 1, Bild 2 von 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    Frag FixBot
    Kommentar hinzufügen
  2. Accessing Logicboard: Schritt 2, Bild 1 von 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    Frag FixBot
  3. Accessing Logicboard: Schritt 3, Bild 1 von 2 Accessing Logicboard: Schritt 3, Bild 2 von 2
    • Carefully pull the back of casing away from the front.
    Frag FixBot
  4. Accessing Logicboard: Schritt 4, Bild 1 von 3 Accessing Logicboard: Schritt 4, Bild 2 von 3 Accessing Logicboard: Schritt 4, Bild 3 von 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    Frag FixBot
  5. Accessing Logicboard: Schritt 5, Bild 1 von 2 Accessing Logicboard: Schritt 5, Bild 2 von 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    Frag FixBot
  6. Accessing Logicboard, Logicboard: Schritt 6, Bild 1 von 2 Accessing Logicboard, Logicboard: Schritt 6, Bild 2 von 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
    Frag FixBot
  7. Accessing Logicboard: Schritt 7, Bild 1 von 2 Accessing Logicboard: Schritt 7, Bild 2 von 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
    Frag FixBot
  8. Accessing Logicboard: Schritt 8, Bild 1 von 1
    • Pull the cover plate off for the two power cord jacks.
    Frag FixBot
  9. Accessing Logicboard: Schritt 9, Bild 1 von 3 Accessing Logicboard: Schritt 9, Bild 2 von 3 Accessing Logicboard: Schritt 9, Bild 3 von 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    Frag FixBot
  10. Accessing Logicboard: Schritt 10, Bild 1 von 1
    • Remove the orange tape on top of the SD cardholder.
    Frag FixBot
  11. Accessing Logicboard: Schritt 11, Bild 1 von 1
    • Open the battery cover.
    Frag FixBot
  12. Accessing Logicboard: Schritt 12, Bild 1 von 2 Accessing Logicboard: Schritt 12, Bild 2 von 2
    • Lift the indicated plastic piece off.
    Frag FixBot
  13. Accessing Logicboard: Schritt 13, Bild 1 von 2 Accessing Logicboard: Schritt 13, Bild 2 von 2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
    Frag FixBot
  14. Accessing Logicboard: Schritt 14, Bild 1 von 1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
    Frag FixBot
  15. Accessing Logicboard: Schritt 15, Bild 1 von 3 Accessing Logicboard: Schritt 15, Bild 2 von 3 Accessing Logicboard: Schritt 15, Bild 3 von 3
    • Carefully lift up SD cardholder to reveal logicboard.
    Frag FixBot
Abschluss
Cal Poly, Team 4-29, Regan Winter 2011 Mitglied von Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 41
Insgesamt: 1,965
