Zum Hauptinhalt wechseln
Alcatel Jitterbug Smart Battery Replacement
Was du brauchst
  1. Alcatel Jitterbug Smart  Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Alcatel Jitterbug Smart  Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. Alcatel Jitterbug Smart  Battery Replacement: Schritt 2, Bild 1 von 3 Alcatel Jitterbug Smart  Battery Replacement: Schritt 2, Bild 2 von 3 Alcatel Jitterbug Smart  Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
    Frag FixBot
  3. Alcatel Jitterbug Smart  Battery Replacement: Schritt 3, Bild 1 von 2 Alcatel Jitterbug Smart  Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
    Frag FixBot
  4. Alcatel Jitterbug Smart  Battery Replacement: Schritt 4, Bild 1 von 2 Alcatel Jitterbug Smart  Battery Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S11-G4, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G4, Cheng Spring 2018
USFT-CHENG-S18S11G4
4 Mitglieder
15 Anleitungen geschrieben
5 Kommentare zur Anleitung
After reading my user guide, I searched how to replace a battery on a Jitterbug Smart2 and had several hits. I connected with this one: Alcatel Jitterbug Smart Battery Replacement 104708#. I see this is the site you have, so I began to follow instructions. When I took the back off of my phone, I saw it looks different from the one you show. Also, mine says this is a non-removeable battery. What do I do now?
Shirley Anderson - Antwort Teilen
I just called Great Call. They told me the battery is not replaceable. I’ll risk it anyway: What’s the point of a cordless phone that doesn’t work without a cord?
Robert L Lazzara - Antwort Teilen
I followed your directions step by step to remove the battery but on my Jitterbug Smart I, there are only 12 screws instead of 13! Your photo shows a screw in the middle near the camera lens but on my phone, that screw does not exist and the word void is printed in it’s place where the screw would be. Because of this, I was unable to remove the mid frame to get access to the battery. It seems to be stuck where the lens is situated making it impossible to remove and I don’t want to break it off.
Ed Johnston - Antwort Teilen
i'm sure it's too late for this comment to be helpful to the original poster, but the sticker that says VOID is covering the final screw and that's why it won't come off. that sticker is there so they can prove that you disassembled it and therefore voided your warranty.
David Jansen - Antwort Teilen
Jitterbug Smart 2 has a NON REMOVEABLE BATTERY. These bogus instructions sell a lot of U$ELE$$ batteries
Jerry Mobley - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 70
Insgesamt: 18,290
