Zum Hauptinhalt wechseln
Asus ROG Ally Left Fan Replacement
Was du brauchst
  1. Asus ROG Ally Left Fan Replacement, Prepare your device for disassembly: Schritt 1, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Prepare your device for disassembly: Schritt 1, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Prepare your device for disassembly: Schritt 1, Bild 3 von 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Left Fan Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 2 Asus ROG Ally Left Fan Replacement, Unfasten the back cover: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Left Fan Replacement, Insert an opening pick: Schritt 3, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Insert an opening pick: Schritt 3, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Insert an opening pick: Schritt 3, Bild 3 von 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Left Fan Replacement, Release the back cover's clips: Schritt 4, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Release the back cover's clips: Schritt 4, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Release the back cover's clips: Schritt 4, Bild 3 von 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Left Fan Replacement, Remove the back cover: Schritt 5, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Remove the back cover: Schritt 5, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Remove the back cover: Schritt 5, Bild 3 von 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Left Fan Replacement, Remove the plastic cover: Schritt 6, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Remove the plastic cover: Schritt 6, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Remove the plastic cover: Schritt 6, Bild 3 von 3
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally Left Fan Replacement, Unlatch the locking bar: Schritt 7, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Unlatch the locking bar: Schritt 7, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Unlatch the locking bar: Schritt 7, Bild 3 von 3
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally Left Fan Replacement, Disconnect the battery: Schritt 8, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Disconnect the battery: Schritt 8, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Disconnect the battery: Schritt 8, Bild 3 von 3
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally Left Fan Replacement, Unfasten the battery: Schritt 9, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Unfasten the battery: Schritt 9, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Unfasten the battery: Schritt 9, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery:
    • Two 9.6 mm‑long screws near the center of the top edge
    • The screw near the left speaker has a warning sticker on it. Pierce through it with your screwdriver or use tweezers to remove it.
    • Two 3.4 mm‑long screws at the left and right edges
  10. Asus ROG Ally Left Fan Replacement, Remove the battery: Schritt 10, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Remove the battery: Schritt 10, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Remove the battery: Schritt 10, Bild 3 von 3
    • With one hand, hold the ribbon cable that runs along the top of the battery out of the way.
    • With your free hand, lift the battery straight up and remove it.
  11. Asus ROG Ally Left Fan Replacement, Separate the fan tape: Schritt 11, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Separate the fan tape: Schritt 11, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Separate the fan tape: Schritt 11, Bild 3 von 3
    • The left fan will be on your right-hand side since your device is laying upside down.
    • Insert the point of a spudger between the tape on the upper edge of the fan and the heatsink foam.
    • Slide the spudger under the length of the tape to separate it from the foam.
    • During reassembly, press the tape back into place to secure it to the heatsink foam.
  12. Asus ROG Ally Left Fan Replacement, Unfasten the left fan: Schritt 12, Bild 1 von 2 Asus ROG Ally Left Fan Replacement, Unfasten the left fan: Schritt 12, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the 9.6 mm‑long screw securing the left fan.
  13. Asus ROG Ally Left Fan Replacement, Reposition the left fan: Schritt 13, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Reposition the left fan: Schritt 13, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Reposition the left fan: Schritt 13, Bild 3 von 3
    • Gently lift the fan and set it on top of the heatsink foam so you can access the fan cables.
    • Be very careful not to strain the cables, as they can easily be damaged.
  14. Asus ROG Ally Left Fan Replacement, Remove the fan cable tape: Schritt 14, Bild 1 von 3 Asus ROG Ally Left Fan Replacement, Remove the fan cable tape: Schritt 14, Bild 2 von 3 Asus ROG Ally Left Fan Replacement, Remove the fan cable tape: Schritt 14, Bild 3 von 3
    • Be very careful not to scrape off or damage any of the components on the motherboard during the next two steps.
    • Use tweezers to peel up and remove the piece of tape securing the fan cables to the motherboard.
    • Put the tape aside. You'll use it during reassembly.
  15. Asus ROG Ally Left Fan Replacement, Disconnect the left fan: Schritt 15, Bild 1 von 2 Asus ROG Ally Left Fan Replacement, Disconnect the left fan: Schritt 15, Bild 2 von 2
    • Use angled tweezers to pull the fan cable connector straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
  16. Asus ROG Ally Left Fan Replacement, Remove the left fan: Schritt 16, Bild 1 von 1
    • Remove the left fan.
    • If your replacement fan doesn't come with tape installed, transfer it from the old fan.
Abschluss
Spencer Day
94.629 Reputation
662 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.418 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 51
Insgesamt: 782
