Einleitung
Use this guide to replace the right bumper in your Backbone One.
Was du brauchst
Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
Disconnect the cable by pulling it straight out the ZIF connector.
Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
Separate the the upper case of the left controller handle.
Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
Repair didn’t go as planned? Ask our Answers community for help.
