Zum Hauptinhalt wechseln
Canon EOS 30 Remote Control Socket Replacement
Was du brauchst
    1. Canon EOS 30 Remote Control Socket Replacement, Front Panel: Schritt 1, Bild 1 von 1
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      Frag FixBot
      Kommentar hinzufügen
    2. Canon EOS 30 Remote Control Socket Replacement: Schritt 2, Bild 1 von 1
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      Frag FixBot
    3. Canon EOS 30 Remote Control Socket Replacement: Schritt 3, Bild 1 von 1
      • Remove the 4.8 mm black screw on the left side of the camera.
      Frag FixBot
    4. Canon EOS 30 Remote Control Socket Replacement: Schritt 4, Bild 1 von 1
      • Remove the front panel by lifting it away from the camera's body.
      Frag FixBot
    1. Canon EOS 30 Remote Control Socket Replacement, Bottom Panel: Schritt 5, Bild 1 von 1
      • Remove seven 4.25 mm black screws on the bottom panel.
      Frag FixBot
    2. Canon EOS 30 Remote Control Socket Replacement: Schritt 6, Bild 1 von 1
      • Remove the bottom panel.
      Frag FixBot
    1. Canon EOS 30 Remote Control Socket Replacement, Side Panel With Remote Control Socket: Schritt 7, Bild 1 von 1
      • Remove two 6.5 mm black screws from the panel.
      Frag FixBot
    2. Canon EOS 30 Remote Control Socket Replacement: Schritt 8, Bild 1 von 1
      • Remove the plastic remote control socket cap by pulling it straight out.
      Frag FixBot
    3. Canon EOS 30 Remote Control Socket Replacement: Schritt 9, Bild 1 von 2 Canon EOS 30 Remote Control Socket Replacement: Schritt 9, Bild 2 von 2
      • Slide the panel toward the bottom of the camera to remove.
      Frag FixBot
    4. Canon EOS 30 Remote Control Socket Replacement: Schritt 10, Bild 1 von 1
      • Remove the single 4.8 silver screw from the control socket.
      Frag FixBot
    5. Canon EOS 30 Remote Control Socket Replacement: Schritt 11, Bild 1 von 2 Canon EOS 30 Remote Control Socket Replacement: Schritt 11, Bild 2 von 2
      • The control socket is now secure by three wires.
      • Desolder connections to replace the remote control socket.
      Frag FixBot
    1. Canon EOS 30 Remote Control Socket Replacement, Remote Control Socket: Schritt 12, Bild 1 von 1
      • Remove one 4.8 mm silver screw securing Remote Control Socket to camera.
      Frag FixBot
    2. Canon EOS 30 Remote Control Socket Replacement: Schritt 13, Bild 1 von 2 Canon EOS 30 Remote Control Socket Replacement: Schritt 13, Bild 2 von 2
      • Remote Control Socket is now secured by 3 wires.
      • Desolder connections to replace Remote Control Socket.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Antonia
124 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
22 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 51
Insgesamt: 3,455
