Einleitung
This guide demonstrates how to remove the back cover to your Dell G15-5510 Gaming laptop.
Was du brauchst
Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
Two 8 mm screws
Two 5.8 mm screws
Loosen the four captive screws.
Insert an opening pick between the bottom-left corner of the back cover and the chassis.
Pry upward to release clips holding the cover in place.
Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
Pry up to release the remaining clips securing the back cover.
Grip the front of the back cover and lift it away from the laptop.
Pull the back cover towards you to disconnect the clips along the top of the back cover.
Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
