Einleitung
This guide will show you how to replace the battery of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Was du brauchst
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
