Zum Hauptinhalt wechseln
Dell Inspiron 11-3168 Battery Replacement
Was du brauchst
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3168 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 11-3168 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 11-3168 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11-3168 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11-3168 Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 11-3168 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 11-3168 Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - Antwort
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 941
