Einleitung
This guide shows how to replace your Dell Inspiron 15-7547's battery.
Was du brauchst
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Eine weitere Person hat diese Anleitung absolviert.
