Zum Hauptinhalt wechseln
Dell Latitude 7410 Fan Replacement
Was du brauchst
  1. Dell Latitude 7410 Fan Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 1
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 Fan Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 Fan Replacement, Insert an opening pick: Schritt 3, Bild 1 von 2 Dell Latitude 7410 Fan Replacement, Insert an opening pick: Schritt 3, Bild 2 von 2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 Fan Replacement, Unclip the right edge: Schritt 4, Bild 1 von 2 Dell Latitude 7410 Fan Replacement, Unclip the right edge: Schritt 4, Bild 2 von 2
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 Fan Replacement, Unclip the left edge: Schritt 5, Bild 1 von 3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: Schritt 5, Bild 2 von 3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: Schritt 5, Bild 3 von 3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 Fan Replacement, Unclip the back edge: Schritt 6, Bild 1 von 3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: Schritt 6, Bild 2 von 3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: Schritt 6, Bild 3 von 3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 Fan Replacement, Unclip the front edge: Schritt 7, Bild 1 von 2 Dell Latitude 7410 Fan Replacement, Unclip the front edge: Schritt 7, Bild 2 von 2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 Fan Replacement, Remove the back cover: Schritt 8, Bild 1 von 2 Dell Latitude 7410 Fan Replacement, Remove the back cover: Schritt 8, Bild 2 von 2
    • Remove the back cover.
  9. Dell Latitude 7410 Fan Replacement, Disconnect the battery: Schritt 9, Bild 1 von 2 Dell Latitude 7410 Fan Replacement, Disconnect the battery: Schritt 9, Bild 2 von 2
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 Fan Replacement, Disconnect the fan: Schritt 10, Bild 1 von 3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: Schritt 10, Bild 2 von 3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: Schritt 10, Bild 3 von 3
    • Use a spudger to press on alternating sides of the fan connector to "walk" it out of its socket.
  11. Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: Schritt 11, Bild 1 von 3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: Schritt 11, Bild 2 von 3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: Schritt 11, Bild 3 von 3
    • Use your Phillips screwdriver to remove the 3 mm screw securing the WLAN connector cover.
    • Remove the cover.
  12. Dell Latitude 7410 Fan Replacement, Unfasten the fan: Schritt 12, Bild 1 von 1
    • Use your Phillips screwdriver to remove the two 3 mm screws securing the fan.
  13. Dell Latitude 7410 Fan Replacement, Remove the fan: Schritt 13, Bild 1 von 3 Dell Latitude 7410 Fan Replacement, Remove the fan: Schritt 13, Bild 2 von 3 Dell Latitude 7410 Fan Replacement, Remove the fan: Schritt 13, Bild 3 von 3
    • Slide the fan out from the heatsink and remove it.
Abschluss
Clay Eickemeyer
70.411 Reputation
453 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
140 Mitglieder
18.109 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 262
