Zum Hauptinhalt wechseln
Dell Latitude 7490 SSD Replacement
Was du brauchst
  1. Dell Latitude 7490 SSD Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 2 Dell Latitude 7490 SSD Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 2 von 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Dell Latitude 7490 SSD Replacement, Flip your laptop over: Schritt 2, Bild 1 von 1
    • Flip your laptop over so the rubber feet strips are facing up.
  3. Dell Latitude 7490 SSD Replacement, Loosen the captive screws: Schritt 3, Bild 1 von 2 Dell Latitude 7490 SSD Replacement, Loosen the captive screws: Schritt 3, Bild 2 von 2
    • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
  4. Dell Latitude 7490 SSD Replacement, Insert an opening pick: Schritt 4, Bild 1 von 3 Dell Latitude 7490 SSD Replacement, Insert an opening pick: Schritt 4, Bild 2 von 3 Dell Latitude 7490 SSD Replacement, Insert an opening pick: Schritt 4, Bild 3 von 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Insert the long side of an opening pick between the top right corner of the back cover and frame.
    • Pry the back cover up to release the clips securing the top right corner.
  5. Dell Latitude 7490 SSD Replacement, Release the clips: Schritt 5, Bild 1 von 3 Dell Latitude 7490 SSD Replacement, Release the clips: Schritt 5, Bild 2 von 3 Dell Latitude 7490 SSD Replacement, Release the clips: Schritt 5, Bild 3 von 3
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Dell Latitude 7490 SSD Replacement: Schritt 6, Bild 1 von 3 Dell Latitude 7490 SSD Replacement: Schritt 6, Bild 2 von 3 Dell Latitude 7490 SSD Replacement: Schritt 6, Bild 3 von 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Dell Latitude 7490 SSD Replacement, Remove the back cover: Schritt 7, Bild 1 von 3 Dell Latitude 7490 SSD Replacement, Remove the back cover: Schritt 7, Bild 2 von 3 Dell Latitude 7490 SSD Replacement, Remove the back cover: Schritt 7, Bild 3 von 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
  8. Dell Latitude 7490 SSD Replacement, Disconnect the battery: Schritt 8, Bild 1 von 2 Dell Latitude 7490 SSD Replacement, Disconnect the battery: Schritt 8, Bild 2 von 2
    • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
    • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
  9. Dell Latitude 7490 SSD Replacement, Unfasten the SSD: Schritt 9, Bild 1 von 2 Dell Latitude 7490 SSD Replacement, Unfasten the SSD: Schritt 9, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 3.7 mm‑long screw securing the SSD.
  10. Dell Latitude 7490 SSD Replacement: Schritt 10, Bild 1 von 3 Dell Latitude 7490 SSD Replacement: Schritt 10, Bild 2 von 3 Dell Latitude 7490 SSD Replacement: Schritt 10, Bild 3 von 3
    • Gently lift the SSD until its bottom edge clears the speaker.
    • Only pull the SSD up enough to clear the speaker—extreme angles can damage the SSD and its socket.
    • Pull the SSD straight out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle into its socket before pushing it in completely.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
161.716 Reputation
1.045 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
24.065 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 157
Insgesamt: 4,320
