Zum Hauptinhalt wechseln
DigiTech RP70 LED Light Replacement
Was du brauchst
    1. DigiTech RP70  LED Light Replacement, Motherboard: Schritt 1, Bild 1 von 2 DigiTech RP70  LED Light Replacement, Motherboard: Schritt 1, Bild 2 von 2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Frag FixBot
      Kommentar hinzufügen
    2. DigiTech RP70  LED Light Replacement: Schritt 2, Bild 1 von 2 DigiTech RP70  LED Light Replacement: Schritt 2, Bild 2 von 2
      • Remove the back panel to expose the motherboard.
      Frag FixBot
    3. DigiTech RP70  LED Light Replacement: Schritt 3, Bild 1 von 1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Frag FixBot
    4. DigiTech RP70  LED Light Replacement: Schritt 4, Bild 1 von 1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Frag FixBot
    1. DigiTech RP70  LED Light Replacement, LED Light: Schritt 5, Bild 1 von 1
      • Desolder the back of the motherboard where the LED light is located.
      Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 562
