Zum Hauptinhalt wechseln
Disassembling Nokia 3395 Screen
Was du brauchst
  1. Disassembling Nokia 3395 Screen, Back Case: Schritt 1, Bild 1 von 3 Disassembling Nokia 3395 Screen, Back Case: Schritt 1, Bild 2 von 3 Disassembling Nokia 3395 Screen, Back Case: Schritt 1, Bild 3 von 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Nokia 3395 Screen, Battery: Schritt 2, Bild 1 von 2 Disassembling Nokia 3395 Screen, Battery: Schritt 2, Bild 2 von 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Frag FixBot
  3. Disassembling Nokia 3395 Screen, Front Case: Schritt 3, Bild 1 von 2 Disassembling Nokia 3395 Screen, Front Case: Schritt 3, Bild 2 von 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Frag FixBot
  4. Disassembling Nokia 3395 Screen, Screen: Schritt 4, Bild 1 von 2 Disassembling Nokia 3395 Screen, Screen: Schritt 4, Bild 2 von 2
    • Remove six T6 screws.
    Frag FixBot
  5. Disassembling Nokia 3395 Screen: Schritt 5, Bild 1 von 2 Disassembling Nokia 3395 Screen: Schritt 5, Bild 2 von 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cal Poly, Team 30-41, Garner Spring 2010 Mitglied von Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 43
Insgesamt: 2,857
