Einleitung
Use this guide to replace the front camera in your Fairphone 4.
Was du brauchst
Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
Slide along the left side of the phone to loosen the plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lift the battery out of its recess and remove it.
Remove the battery.
Insert an opening pick beneath the cover near the triangular mark.
Twist the opening pick to pry the cover up.
Remove the cover.
Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
Lift up the right connector to reveal the additional connector beneath it.
Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
Use an opening pick to slide underneath the rear camera module.
Slide the opening pick along the rear camera module to release the clips that hold it in place.
Use an opening pick to pry up and disconnect the front camera cable.
Use an opening pick to lift out the front camera by carefully pulling it away from the frame so it pops out of its recess.
