Zum Hauptinhalt wechseln
Framework Laptop 16" Numpad Replacement
  1. Framework Laptop 16" Numpad Replacement, Before you begin: Schritt 1, Bild 1 von 2 Framework Laptop 16" Numpad Replacement, Before you begin: Schritt 1, Bild 2 von 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Numpad Replacement, Unlock the Input Modules: Schritt 2, Bild 1 von 3 Framework Laptop 16" Numpad Replacement, Unlock the Input Modules: Schritt 2, Bild 2 von 3 Framework Laptop 16" Numpad Replacement, Unlock the Input Modules: Schritt 2, Bild 3 von 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Numpad Replacement, Remove the touchpad spacers: Schritt 3, Bild 1 von 3 Framework Laptop 16" Numpad Replacement, Remove the touchpad spacers: Schritt 3, Bild 2 von 3 Framework Laptop 16" Numpad Replacement, Remove the touchpad spacers: Schritt 3, Bild 3 von 3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Numpad Replacement: Schritt 4, Bild 1 von 1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Numpad Replacement, Remove the touchpad: Schritt 5, Bild 1 von 3 Framework Laptop 16" Numpad Replacement, Remove the touchpad: Schritt 5, Bild 2 von 3 Framework Laptop 16" Numpad Replacement, Remove the touchpad: Schritt 5, Bild 3 von 3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Numpad Replacement, Remove the numpad: Schritt 6, Bild 1 von 3 Framework Laptop 16" Numpad Replacement, Remove the numpad: Schritt 6, Bild 2 von 3 Framework Laptop 16" Numpad Replacement, Remove the numpad: Schritt 6, Bild 3 von 3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
Alex Diaz-Kokaisl
213.706 Reputation
1.041 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.725 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 339
