Zum Hauptinhalt wechseln
Garmin Edge 530 Back Cover Replacement
Was du brauchst
    1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: Schritt 1, Bild 1 von 1
      • Insert the metal spudger between the edge of the device screen and back cover.
      • Begin to pry along the perimeter between the device screen and back cover.
      Frag FixBot
      Kommentar hinzufügen
    2. Garmin Edge 530 Back Cover  Replacement: Schritt 2, Bild 1 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 2, Bild 2 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 2, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Halberd Spudger
      $2.99
      • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
      • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
      Frag FixBot
    3. Garmin Edge 530 Back Cover  Replacement: Schritt 3, Bild 1 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 3, Bild 2 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 3, Bild 3 von 3
      • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
      Frag FixBot
    4. Garmin Edge 530 Back Cover  Replacement: Schritt 4, Bild 1 von 1
      • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
      • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
      Frag FixBot
    1. Garmin Edge 530 Back Cover  Replacement, Motherboard: Schritt 5, Bild 1 von 2 Garmin Edge 530 Back Cover  Replacement, Motherboard: Schritt 5, Bild 2 von 2
      Halberd Spudger
      $2.99
      • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
      • Gently peel back the copper adhesive strip to free the remaining bonding cable.
      Frag FixBot
    2. Garmin Edge 530 Back Cover  Replacement: Schritt 6, Bild 1 von 1
      • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
      Frag FixBot
    3. Garmin Edge 530 Back Cover  Replacement: Schritt 7, Bild 1 von 2 Garmin Edge 530 Back Cover  Replacement: Schritt 7, Bild 2 von 2
      • Take the motherboard out of the back cover.
      • You will remove the wire harness in the next step.
      Frag FixBot
    4. Garmin Edge 530 Back Cover  Replacement: Schritt 8, Bild 1 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 8, Bild 2 von 3 Garmin Edge 530 Back Cover  Replacement: Schritt 8, Bild 3 von 3
      $3.99
      • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
      • Now the motherboard and compartment are separated.
      Frag FixBot
    1. Garmin Edge 530 Back Cover  Replacement, Back Cover: Schritt 9, Bild 1 von 1
      • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
      • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 2-1, Hunter Spring 2022 Mitglied von Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 37
Letzte 30 Tage: 168
Insgesamt: 6,002
