Zum Hauptinhalt wechseln
Garmin Rino 700 Battery Replacement
Was du brauchst
  1. Garmin Rino 700 Battery Replacement, Battery Disconnect: Schritt 1, Bild 1 von 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Battery Replacement: Schritt 2, Bild 1 von 2 Garmin Rino 700 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Battery Replacement: Schritt 3, Bild 1 von 2 Garmin Rino 700 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Garmin Rino 700 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Garmin Rino 700 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Using a Phillips #000 screwdriver, remove the two 4.8 mm screws holding the battery bracket in place.
    • Using a plastic opening tool, remove the battery from the back case of the device.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Abigail Dugan
512 Reputation
5 Anleitungen geschrieben
Clemson, Team 5-5, Hunter Fall 2021 Mitglied von Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 1,133
