Einleitung
Use this guide to remove and replace the back cover on your HP EliteBook x360 830 G6. The process of removing the back cover is necessary for nearly all repairs and upgrades for your laptop.
Was du brauchst
Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
Pry up to release the additional retaining clips.
Grab the cover by the corners next to the hinges.
Swing the cover open and away from you.
Lift and remove the back cover from the laptop body.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
