Zum Hauptinhalt wechseln
HP Stream 7 Motherboard Replacement
Was du brauchst
    1. HP Stream 7  Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 HP Stream 7  Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Frag FixBot
      Kommentar hinzufügen
    2. HP Stream 7  Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Stream 7  Motherboard Replacement: Schritt 2, Bild 2 von 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Frag FixBot
    3. HP Stream 7  Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Stream 7  Motherboard Replacement: Schritt 3, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Frag FixBot
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: Schritt 4, Bild 1 von 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Frag FixBot
    2. HP Stream 7  Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Stream 7  Motherboard Replacement: Schritt 5, Bild 2 von 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Frag FixBot
    3. HP Stream 7  Motherboard Replacement: Schritt 6, Bild 1 von 2 HP Stream 7  Motherboard Replacement: Schritt 6, Bild 2 von 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 18-5, Forte Fall 2016 Mitglied von Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 42
Insgesamt: 2,108
