Zum Hauptinhalt wechseln
HP Stream 7 Screen Replacement
Was du brauchst
  1. HP Stream 7  Screen Replacement, Battery: Schritt 1, Bild 1 von 2 HP Stream 7  Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Stream 7  Screen Replacement: Schritt 2, Bild 1 von 2 HP Stream 7  Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
    Frag FixBot
  3. HP Stream 7  Screen Replacement: Schritt 3, Bild 1 von 2 HP Stream 7  Screen Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
    Frag FixBot
  4. HP Stream 7  Screen Replacement, Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
    • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
    • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
    • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
    Frag FixBot
  5. HP Stream 7  Screen Replacement: Schritt 5, Bild 1 von 2 HP Stream 7  Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 2 mm Phillips 000 screws from the motherboard.
    Frag FixBot
  6. HP Stream 7  Screen Replacement: Schritt 6, Bild 1 von 2 HP Stream 7  Screen Replacement: Schritt 6, Bild 2 von 2
    • Once unscrewed, the motherboard separates from the rest of the device.
    • The speaker is soldered to the motherboard, but it comes off easily.
    • Forced separation may result in a damaged motherboard and/or personal injury.
    Frag FixBot
  7. HP Stream 7  Screen Replacement, Screen Replacement: Schritt 7, Bild 1 von 1
    • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
    Frag FixBot
  8. HP Stream 7  Screen Replacement: Schritt 8, Bild 1 von 1
    • Using your spudger, pry the display panel off the front.
    Frag FixBot
  9. HP Stream 7  Screen Replacement: Schritt 9, Bild 1 von 1
    • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 18-5, Forte Fall 2016 Mitglied von Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Mitglieder
6 Anleitungen geschrieben
6 Kommentare zur Anleitung
where can i buy new screen????
eibrims - Antwort Teilen
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Antwort Teilen
Where can i buy a new screen for the stream 7 please??
migueajr - Antwort Teilen
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Antwort Teilen
We're I can buy the replacement screen?
Raymond Borrero - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 4,717
