Zum Hauptinhalt wechseln
Hamilton Beach Power Cord Replacement
Was du brauchst
    1. Hamilton Beach  Power Cord Replacement, Motor: Schritt 1, Bild 1 von 3 Hamilton Beach  Power Cord Replacement, Motor: Schritt 1, Bild 2 von 3 Hamilton Beach  Power Cord Replacement, Motor: Schritt 1, Bild 3 von 3
      • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
      Frag FixBot
      Kommentar hinzufügen
    2. Hamilton Beach  Power Cord Replacement: Schritt 2, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 2, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 2, Bild 3 von 3
      • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
      Frag FixBot
    3. Hamilton Beach  Power Cord Replacement: Schritt 3, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 3, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 3, Bild 3 von 3
      • Carefully pull the motor block out of the case.
      • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
      • Handle the wires with care to ensure you do not break any of them.
      Frag FixBot
    4. Hamilton Beach  Power Cord Replacement: Schritt 4, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 4, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 4, Bild 3 von 3
      • Desolder the six wires connected to the motor using this guide.
      • Make sure to note colors when you disconnect them and remember where to reconnect them later.
      Frag FixBot
    5. Hamilton Beach  Power Cord Replacement: Schritt 5, Bild 1 von 2 Hamilton Beach  Power Cord Replacement: Schritt 5, Bild 2 von 2
      • Once disconnected, the motor will slide out easily.
      Frag FixBot
    1. Hamilton Beach  Power Cord Replacement, Speed Level: Schritt 6, Bild 1 von 3 Hamilton Beach  Power Cord Replacement, Speed Level: Schritt 6, Bild 2 von 3 Hamilton Beach  Power Cord Replacement, Speed Level: Schritt 6, Bild 3 von 3
      • Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
      Frag FixBot
    2. Hamilton Beach  Power Cord Replacement: Schritt 7, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 7, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 7, Bild 3 von 3
      • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
      Frag FixBot
    3. Hamilton Beach  Power Cord Replacement: Schritt 8, Bild 1 von 2 Hamilton Beach  Power Cord Replacement: Schritt 8, Bild 2 von 2
      • Remove the handle's cap carefully.
      • Watch out for the quick burst button, it likes to run away.
      Frag FixBot
    4. Hamilton Beach  Power Cord Replacement: Schritt 9, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 9, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 9, Bild 3 von 3
      • Slide the speed switch forward and lift upward off of the handle.
      Frag FixBot
    5. Hamilton Beach  Power Cord Replacement: Schritt 10, Bild 1 von 2 Hamilton Beach  Power Cord Replacement: Schritt 10, Bild 2 von 2
      • Remove speed level from the inside of the case by applying light pressure toward you.
      • Do not pull on the wires to remove the speed level.
      Frag FixBot
    6. Hamilton Beach  Power Cord Replacement: Schritt 11, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 11, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 11, Bild 3 von 3
      • Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
      • Replace the speed level assembly.
      Frag FixBot
    1. Hamilton Beach  Power Cord Replacement, Power Cord: Schritt 12, Bild 1 von 3 Hamilton Beach  Power Cord Replacement, Power Cord: Schritt 12, Bild 2 von 3 Hamilton Beach  Power Cord Replacement, Power Cord: Schritt 12, Bild 3 von 3
      • Liftback end of the handle up from motor casing.
      • Pull back to detach fully from the stainless steel.
      Frag FixBot
    2. Hamilton Beach  Power Cord Replacement: Schritt 13, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 13, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 13, Bild 3 von 3
      • Remove the three 7.8 mm Philips #2 screws holding the power cord in place.
      Frag FixBot
    3. Hamilton Beach  Power Cord Replacement: Schritt 14, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 14, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 14, Bild 3 von 3
      • Cut zip tie holding the power cable together using handheld wire cutters.
      Frag FixBot
    4. Hamilton Beach  Power Cord Replacement: Schritt 15, Bild 1 von 3 Hamilton Beach  Power Cord Replacement: Schritt 15, Bild 2 von 3 Hamilton Beach  Power Cord Replacement: Schritt 15, Bild 3 von 3
      • Untie the black lead's knot.
      • Cut both wires with handheld wire cutters.
      • Follow this guide to solder new power cord wires in.
      Frag FixBot
Abschluss
UMass Dartmouth, Team 7-3, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-3, Catania Spring 2016
UMASSD-CATANIA-S16S7G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 2,024
