Einleitung
Use this guide to fix the mouse if there is a double click problem on your Logitech G403.
Double clicking is a very common problem for G403. If your warranty is finished, you can fix the mouse by yourself, rather than buy a new one.
You will need a precision screwdriver set to fix the mouse. However, in case your screwdriver doesn’t work, you can look at these pages for help:
Don’t forget to unplug your mouse before you start.
Was du brauchst
Use a prying tool or your hand to take out both sides of the mouse feet.
Slowly open the mouse, and take care not to tear the ribbon cable.
Detach the cable connector.
Find the place where more tension is needed.
Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
10 weitere Personen haben diese Anleitung absolviert.
10 Kommentare zur Anleitung
Worked, thanks
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
