Zum Hauptinhalt wechseln
How to Open the GuliKit KingKong 2 Pro
Was du brauchst
  1. How to Open the GuliKit KingKong 2 Pro, Unfasten the back cover screws: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
    Frag FixBot
  2. How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: Schritt 2, Bild 1 von 2 How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: Schritt 2, Bild 2 von 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
    Frag FixBot
  3. How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: Schritt 3, Bild 1 von 2 How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: Schritt 3, Bild 2 von 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
    Frag FixBot
  4. How to Open the GuliKit KingKong 2 Pro: Schritt 4, Bild 1 von 2 How to Open the GuliKit KingKong 2 Pro: Schritt 4, Bild 2 von 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
    Frag FixBot
  5. How to Open the GuliKit KingKong 2 Pro, Remove the back cover: Schritt 5, Bild 1 von 2 How to Open the GuliKit KingKong 2 Pro, Remove the back cover: Schritt 5, Bild 2 von 2
    • Separate the back cover from the front assembly and remove it.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.808 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 108
Insgesamt: 8,245
