Zum Hauptinhalt wechseln
How to Open the Left Handle of the Backbone One
Was du brauchst
  1. How to Open the Left Handle of the Backbone One, Unfasten the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Open the Left Handle of the Backbone One, Rotate the upper cover: Schritt 2, Bild 1 von 3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: Schritt 2, Bild 2 von 3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: Schritt 2, Bild 3 von 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Frag FixBot
  3. How to Open the Left Handle of the Backbone One, Remove the protective tape: Schritt 3, Bild 1 von 3 How to Open the Left Handle of the Backbone One, Remove the protective tape: Schritt 3, Bild 2 von 3 How to Open the Left Handle of the Backbone One, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Frag FixBot
  4. How to Open the Left Handle of the Backbone One, Open the ZIF connector: Schritt 4, Bild 1 von 2 How to Open the Left Handle of the Backbone One, Open the ZIF connector: Schritt 4, Bild 2 von 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Frag FixBot
  5. How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Use your fingers to disconnect the interconnect cable from its connector.
    Frag FixBot
  6. How to Open the Left Handle of the Backbone One: Schritt 6, Bild 1 von 2 How to Open the Left Handle of the Backbone One: Schritt 6, Bild 2 von 2
    • Remove the upper half of the left controller assembly.
    Frag FixBot
Abschluss
Opening didn’t go as planned? Answers community for help.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.813 Anleitungen geschrieben
2 Kommentare zur Anleitung
Did this work for you?
Shawn Gallant - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 90
Insgesamt: 2,024
