Einleitung
Follow these instructions to use a hair dryer to soften adhesive. If you're using a heat gun (which emits much hotter air), follow this guide instead.
A hair dryer is a handheld device that emits a warm stream of air ranging between temperatures of 70 °F and 200 °F (21–93 °C).
Refer to your specific repair guide for detailed instructions on adhesive locations and sensitive components. Check your hair dryer's user manual for operating and safety procedures.
Was du brauchst
Place your device on a clean, heat resistant surface or mat.
Set the temperature of your hair dryer to its "hot" setting.
Set the fan setting to "Low" for small parts, such as cables or tape.
Set the fan setting to "High" for large surfaces, such as screens or back covers.
Position the nozzle of your hair dryer 2–3 inches above the device.
Move the hair dryer along the surface of your device.
Heat the surface until it's hot to the touch, or as directed by the repair guide.
Make sure to turn off your hair dryer before setting it down to continue the repair.
Keep your hair dryer in motion while heating smaller surfaces by moving it in circles above the device.
Some components, such as large screens, require multiple cycles of heating and slicing. Take your time and apply more heat if the component feels stuck.
Position the nozzle of your hair dryer 2–3 inches above the device and set the fan setting to "Low".
Apply heat in small circles over the tape or sticker for 30 seconds.
Peel the tape from the device.
Apply heat in small circles over the cable for 30 seconds.
Peel the cable from the device.
Before continuing your repair, turn off your hair dryer and unplug it.
Allow the hair dryer to cool down before you store it.
For other general electronics skills guides, click here.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
