Einleitung
Use this guide to remove the rear glass of the Huawei Honor 8.
You’ll need replacement adhesive to reattach components when reassembling the device.
Was du brauchst
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction cup to create a small gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the tip of the opening pick from the bottom left corner along the side to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Remove the Phillips #00 screw (2.8 mm length) that secures the metal bracket on top of the fingerprint flex connector.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
