Zum Hauptinhalt wechseln
LG Refrigerator Control Board Replacement
Was du brauchst
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: Schritt 3, Bild 1 von 3 LG Refrigerator Control Board Replacement, Remove the control board cover: Schritt 3, Bild 2 von 3 LG Refrigerator Control Board Replacement, Remove the control board cover: Schritt 3, Bild 3 von 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: Schritt 4, Bild 1 von 3 LG Refrigerator Control Board Replacement, Disconnect the control board: Schritt 4, Bild 2 von 3 LG Refrigerator Control Board Replacement, Disconnect the control board: Schritt 4, Bild 3 von 3
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
  5. LG Refrigerator Control Board Replacement, Release the control board: Schritt 5, Bild 1 von 3 LG Refrigerator Control Board Replacement, Release the control board: Schritt 5, Bild 2 von 3 LG Refrigerator Control Board Replacement, Release the control board: Schritt 5, Bild 3 von 3
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
  6. LG Refrigerator Control Board Replacement: Schritt 6, Bild 1 von 3 LG Refrigerator Control Board Replacement: Schritt 6, Bild 2 von 3 LG Refrigerator Control Board Replacement: Schritt 6, Bild 3 von 3
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
  7. LG Refrigerator Control Board Replacement, Remove the control board: Schritt 7, Bild 1 von 1
    • Lift the control board out by its edges and remove it.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
3 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
38.497 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.618 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 32
Letzte 30 Tage: 141
Insgesamt: 3,476
