Zum Hauptinhalt wechseln
LG Refrigerator Freezer Light Replacement
Was du brauchst
  1. LG Refrigerator Freezer Light Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Light Replacement, Open the freezer door: Schritt 2, Bild 1 von 2 LG Refrigerator Freezer Light Replacement, Open the freezer door: Schritt 2, Bild 2 von 2
    • Pull open the freezer door fully.
  3. LG Refrigerator Freezer Light Replacement, Remove the drawer and bin: Schritt 3, Bild 1 von 3 LG Refrigerator Freezer Light Replacement, Remove the drawer and bin: Schritt 3, Bild 2 von 3 LG Refrigerator Freezer Light Replacement, Remove the drawer and bin: Schritt 3, Bild 3 von 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Light Replacement, Remove the drawer rail covers: Schritt 4, Bild 1 von 3 LG Refrigerator Freezer Light Replacement, Remove the drawer rail covers: Schritt 4, Bild 2 von 3 LG Refrigerator Freezer Light Replacement, Remove the drawer rail covers: Schritt 4, Bild 3 von 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Light Replacement, Reassembly notes: Schritt 5, Bild 1 von 2 LG Refrigerator Freezer Light Replacement, Reassembly notes: Schritt 5, Bild 2 von 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Light Replacement, Remove the drawer: Schritt 6, Bild 1 von 2 LG Refrigerator Freezer Light Replacement, Remove the drawer: Schritt 6, Bild 2 von 2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Light Replacement: Schritt 7, Bild 1 von 3 LG Refrigerator Freezer Light Replacement: Schritt 7, Bild 2 von 3 LG Refrigerator Freezer Light Replacement: Schritt 7, Bild 3 von 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Light Replacement, Unfasten the freezer light: Schritt 8, Bild 1 von 2 LG Refrigerator Freezer Light Replacement, Unfasten the freezer light: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the screw(s) securing the freezer light.
    • Lower the front edge of the freezer light to access its connector.
  9. LG Refrigerator Freezer Light Replacement, Remove the freezer light: Schritt 9, Bild 1 von 3 LG Refrigerator Freezer Light Replacement, Remove the freezer light: Schritt 9, Bild 2 von 3 LG Refrigerator Freezer Light Replacement, Remove the freezer light: Schritt 9, Bild 3 von 3
    • Squeeze the freezer light connector and pull it straight off to disconnect it.
    • Remove the freezer light.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38.494 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.583 Anleitungen geschrieben
1 Kommentar zur Anleitung
Do you know the part number and where to get it? Thanks, very good video.
Steve Tobias - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 37
Letzte 30 Tage: 183
Insgesamt: 3,924
