Einleitung
Use this guide to replace the freezer drawer switch on your LG model LFX25973 Refrigerator.
The freezer drawer switch controls the freezer light and also is monitored by the door alarm.
If it fails, the light may not operate or may stay on continuously, or the door alarm will sound continuously.
Was du brauchst
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
Lift the front of the drawer up.
Pull the drawer toward you to release the drawer from the drawer slides.
Remove the freezer drawer.
Use a Phillips screwdriver to remove the five 22.4 mm‑long screws securing both left drawer slides.
Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
Remove the upper left drawer slide.
Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
Reposition the lower left drawer slide to gain access to the door switch connector.
Squeeze the door switch connector to release it.
Pull the door switch connector down to disconnect it.
Remove the lower left drawer slide.
Check continuity between the two orange wire terminals on the connector.
Press the retaining tab on the switch to release it from the drawer slide assembly.
When it is released, push the switch down through the mounting cutout.
Remove the switch from the drawer slide assembly.
Use a spudger to release the two clips that secure the wiring connector to the door switch.
Pull the connector straight off the drawer switch to disconnect it.
