Einleitung
Use this guide to replace the water filter on your LG LFX25973 Refrigerator.
If your water filter is clogged, your water dispenser may have poor-tasting water and ice cubes, and the flow rate may be reduced. You should change your filter about every six months.
Lift up the front edge of the shelf to release it.
Unhook the shelf and remove it.
Repeat the last two steps for each shelf you wish to remove.
To release your water filter, rotate it one-quarter turn counterclockwise.
