Zum Hauptinhalt wechseln
LG Refrigerator Model LFX25973 Control Board Replacement
Was du brauchst
  1. LG Refrigerator Model LFX25973 Control Board Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator Model LFX25973 Control Board Replacement, Unfasten the control board cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 18.4 mm‑long screws securing the control board cover.
  3. LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: Schritt 3, Bild 1 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: Schritt 3, Bild 2 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: Schritt 3, Bild 3 von 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: Schritt 4, Bild 1 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: Schritt 4, Bild 2 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: Schritt 4, Bild 3 von 3
    • Squeeze and pull the eight connectors to disconnect them from the control board.
  5. LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: Schritt 5, Bild 1 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: Schritt 5, Bild 2 von 3 LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: Schritt 5, Bild 3 von 3
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
  6. LG Refrigerator Model LFX25973 Control Board Replacement: Schritt 6, Bild 1 von 3 LG Refrigerator Model LFX25973 Control Board Replacement: Schritt 6, Bild 2 von 3 LG Refrigerator Model LFX25973 Control Board Replacement: Schritt 6, Bild 3 von 3
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
  7. LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board: Schritt 7, Bild 1 von 1
    • Lift the control board out by its edges and remove it.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38.494 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.608 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 169
