Einleitung
Use this guide to replace the refrigerator compartment light in an LG Refrigerator model LFX25973. The process involves removing the light unit, disconnecting it, and installing a new one.
Was du brauchst
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Lift up the front edge of the shelf to release it.
Unhook the shelf and remove it.
Repeat the last two steps for each shelf you wish to remove.
Use a Phillips screwdriver to remove the two 22.5 mm‑long screws that secure the light unit.
With both hands, pull down the front edge of the light unit until it pops free.
Pinch the light unit connector to release it and pull it out straight to disconnect.
Remove the light unit.
Use a spudger to pry and release the two clips on the rear edge of the light.
Use a spudger to pry and release the sides of the light cover from the light base.
Use a Philips head driver to remove the two 14.5 mm long screws securing the light module.
