Zum Hauptinhalt wechseln
LG Refrigerator Upper Ice Maker Assembly Replacement
Was du brauchst
  1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: Schritt 2, Bild 1 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: Schritt 2, Bild 2 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: Schritt 3, Bild 1 von 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: Schritt 3, Bild 2 von 2
    • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
  4. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: Schritt 4, Bild 1 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: Schritt 4, Bild 2 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: Schritt 4, Bild 3 von 3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  5. LG Refrigerator Upper Ice Maker Assembly Replacement: Schritt 5, Bild 1 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement: Schritt 5, Bild 2 von 3 LG Refrigerator Upper Ice Maker Assembly Replacement: Schritt 5, Bild 3 von 3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  6. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: Schritt 6, Bild 1 von 1
    • Remove the ice maker assembly.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30.088 Reputation
213 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 36
Insgesamt: 134
