Zum Hauptinhalt wechseln
Lenovo ThinkPad T460 Charging Port Replacement
Was du brauchst
  1. Lenovo ThinkPad T460 Charging Port Replacement, External Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement, External Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement, External Battery: Schritt 1, Bild 3 von 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Charging Port Replacement, Bottom Cover: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement, Bottom Cover: Schritt 3, Bild 2 von 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 8, Bild 3 von 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Charging Port Replacement, Charging Port: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement, Charging Port: Schritt 9, Bild 2 von 2
    • Remove two 4.7 mm screws from the hinge in the upper right-hand corner using a Phillips #1 screwdriver.
  10. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 10, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 10, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 10, Bild 3 von 3
    • Lift the bottom of the laptop up by a few inches to rotate the upper right hinge.
    • Place the bottom of the laptop back down.
  11. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 11, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  12. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 12, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 12, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 12, Bild 3 von 3
    • Use your fingers to remove the black cable from its slots above the motherboard.
  13. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 13, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 13, Bild 2 von 2
    • Use your fingers to lift the gray cable out of its slots.
  14. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 14, Bild 1 von 1
    • Remove the single 4.7 mm screw from the charging port bracket using a Phillips #1 screwdriver.
  15. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 15, Bild 1 von 2 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 15, Bild 2 von 2
    • Use your fingers to remove the charging port bracket from the laptop.
  16. Lenovo ThinkPad T460 Charging Port Replacement: Schritt 16, Bild 1 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 16, Bild 2 von 3 Lenovo ThinkPad T460 Charging Port Replacement: Schritt 16, Bild 3 von 3
    • Use your fingers to slide the charging port out from beneath the gray cable to remove it from the laptop.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kristen Gismondi
82.719 Reputation
202 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 38
Letzte 30 Tage: 144
Insgesamt: 4,076
