Zum Hauptinhalt wechseln
Lenovo ThinkPad T460 Smart Card Reader Replacement
Was du brauchst
  1. Lenovo ThinkPad T460 Smart Card Reader Replacement, External Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement, External Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement, External Battery: Schritt 1, Bild 3 von 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 2, Bild 3 von 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Smart Card Reader Replacement, Bottom Cover: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement, Bottom Cover: Schritt 3, Bild 2 von 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 4, Bild 3 von 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 5, Bild 2 von 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 6, Bild 2 von 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 8, Bild 3 von 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Smart Card Reader Replacement, Internal Battery: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement, Internal Battery: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of blunt nose tweezers to pull the black connector out of its socket.
    • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
  10. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 10, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 10, Bild 2 von 2
    • Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
  11. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 11, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 11, Bild 2 von 2
    • Use your hands to lift the battery up and away from the laptop.
  12. Lenovo ThinkPad T460 Smart Card Reader Replacement, Smart Card Reader: Schritt 12, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement, Smart Card Reader: Schritt 12, Bild 2 von 2
    • Remove two 5 mm screws from the speaker in the lower right-hand corner using a Phillips #1 screwdriver.
  13. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 13, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 13, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 13, Bild 3 von 3
    • Use your hand to lift the speaker out of its compartment.
    • The speaker's wire will still be secured to the laptop; it is not necessary to remove the wire.
  14. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 14, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 14, Bild 2 von 2
    • Use your fingers to lift the black flap up from the smart card reader cable connector.
  15. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 15, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 15, Bild 2 von 2
    • Use the pointed end of a spudger to open the white clip on the smart card reader connector.
  16. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 16, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 16, Bild 2 von 2
    Kaufen
    • Use a pair of blunt nose tweezers to slide the cable out of the connector on the smart card reader.
  17. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 17, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 17, Bild 2 von 2
    • Remove two 3.8 mm screws from the smart card reader bracket using a Phillips #1 screwdriver.
  18. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 18, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 18, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 18, Bild 3 von 3
    • Use your fingers to lift the smart card reader bracket up and away from the laptop.
  19. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 19, Bild 1 von 2 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 19, Bild 2 von 2
    • Remove two 3.7 mm screws from the smart card reader using a Phillips #1 screwdriver.
  20. Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 20, Bild 1 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 20, Bild 2 von 3 Lenovo ThinkPad T460 Smart Card Reader Replacement: Schritt 20, Bild 3 von 3
    • Use the flat end of a spudger to pry the smart card reader up by a few millimeters.
    • Use your other hand to lift the smart card reader up and away from the laptop.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kristen Gismondi
82.719 Reputation
202 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 16
Letzte 30 Tage: 49
Insgesamt: 1,535
