Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Hall Sensor Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
    Frag FixBot
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
    Frag FixBot
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
    Frag FixBot
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery near the connector and remove it from the system.
    Frag FixBot
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 3 von 3
    • Use a spudger to disconnect the cable from the Hall sensor.
    Frag FixBot
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 7, Bild 2 von 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
    Frag FixBot
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 3 von 3
    • Remove the sensor from the system.
    Frag FixBot
Abschluss
iFixit Mitglied von iFixit
Staff
122 Mitglieder
27.503 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 90
Insgesamt: 4,963
