Einleitung
Use this guide to replace the SD card reader/audio card from your Lenovo ThinkPad T480s.
If your laptop isn’t producing sound, most likely it’s due to faulty or misconnected cables so be sure to check them. If you know that the speakers have power and the volume is at an audible level, you may need to replace the SD card reader/audio card of your Lenovo ThinkPad T480s. Be sure to troubleshoot any audio issues before attempting to replace it though.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Was du brauchst
Remove the bottom cover with an opening tool.
Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
Disconnect the speaker cable from the motherboard using a connector puller or spudger.
Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
Lift the speakers up.
Disconnect the cable speakers from the routing.
Remove the speakers from the system.
Use a spudger to lift up the retaining flap on the SD card reader/audio card connector.
Lift the SD card reader/audio card from the system by sliding it out from the socket.
