Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s USB Card Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s USB Card Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s USB Card Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s USB Card Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: Schritt 4, Bild 2 von 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s USB Card Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T480s USB Card Replacement: Schritt 5, Bild 2 von 2
    • Loosen the four captive screws attaching the fan assembly to the motherboard.
    • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
  6. Lenovo ThinkPad T480s USB Card Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 6, Bild 3 von 3
    • Lift the fan assembly from the system and remove it.
    • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
  7. Lenovo ThinkPad T480s USB Card Replacement, USB Card: Schritt 7, Bild 1 von 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: Schritt 7, Bild 2 von 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: Schritt 7, Bild 3 von 3
    • Use a spudger to disconnect the cable from the USB card.
  8. Lenovo ThinkPad T480s USB Card Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad T480s USB Card Replacement: Schritt 8, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove two 3 mm screws from the USB card.
  9. Lenovo ThinkPad T480s USB Card Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad T480s USB Card Replacement: Schritt 9, Bild 3 von 3
    • With your fingers, lift the USB card from the system.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
iFixit Mitglied von iFixit
Staff
123 Mitglieder
25.636 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 53
Insgesamt: 1,397
