Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s WWAN Card Replacement
Was du brauchst
    1. Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 2, Bild 3 von 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Frag FixBot
    3. Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 3, Bild 2 von 2
      • Lift the bottom cover off.
      Frag FixBot
    1. Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: Schritt 4, Bild 3 von 3
      • Flip the cardboard cover off of the WWAN card.
      • Using the spudger, release the coaxial antenna wires from the WWAN card.
      • When reassembling, reattach the blue wire on the left and the orange wire on the right.
      Frag FixBot
    2. Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 5, Bild 2 von 2
      • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
      Frag FixBot
    3. Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s WWAN Card Replacement: Schritt 6, Bild 3 von 3
      • Slide the WWAN card out from the slot.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
123 Mitglieder
51.112 Anleitungen geschrieben
1 Kommentar zur Anleitung
You can also install a secondary SSD into the WWAN slot, but it must fit these requirements:
- SSD size: M.2 2242,
- It must be M+B keyed, and
- (Hypothetically, only the SSD being B keyed is needed, but I haven't seen any NVMe SSDs that are only B-keyed.)
- It must be single-sided, with respect to surface-mount components.
Information came from this video for the ThinkPad T480, but the ThinkPad T480s is similar enough to the ThinkPad T480 for this to work.
Tai Lam - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 26
Letzte 30 Tage: 116
Insgesamt: 6,982
