Einleitung
Welcome to the motherboard replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the motherboard.
The most common reasons why this component would need to be replaced are:
- The computer powers on but doesn’t “turn on”
- The computer does not power on
- Your BIOS indicates your motherboard or integrated component is damaged
- You experience frequent crashes, glitches, or other malfunctions, and have ruled out other components as the culprit
There are no specialized skills required for replacing the motherboard.
Was du brauchst
Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
Unplug and remove the battery connector from the motherboard.
Remove the internal battery.
Using a Phillips #00 screwdriver, unscrew five 4.6 mm screws fastening the fan and cooling pipe.
Schritt 12 Wi-Fi Card
Achtung: Die Schritte 12-14 stammen von einer Anleitung, die derzeit bearbeitet wird.
Using a spudger, pop off the gray and black coaxial cables from the Wi-Fi card.
Using a Phillips #00 screwdriver, remove the 3.6 mm screw from the Wi-Fi card.
Schritt 15 RAM
Achtung: Die Schritte 15-17 stammen von einer Anleitung, die derzeit bearbeitet wird.
Pull the two tabs on either side of the RAM card outwards with your fingers.
Remove the RAM module from the laptop.
Repeat the same process for the second RAM module if your computer included one.
Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
Continue prying along the top edge of the keyboard, releasing the clips as you go.
Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
Pull the keyboard away from you, releasing the tabs along the bottom edge.
Flip the keyboard over to rest face down over the trackpad.
Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
Using a Phillips #00 screwdriver, unscrew the three 3.3 mm motherboard screws.
Using a Phillips #00 screwdriver, take out the port clamps and the three 3.6 mm screws.
Flip up the two ZIF cables for the trackpad and fingerprint sensor with the pointed end of a plastic spudger.
Using a spudger, flip up the locking tabs of the two ZIF connectors on the upper left corner of the motherboard.
Pull out each of the ribbon cables using a pair of blunt nose tweezers.
Flip up the locking tab of the ZIF connector on the bottom left of the motherboard.
Pull out the ribbon cable and speaker cable from their connectors using a pair of blunt nose tweezers.
Using a spudger, flip up the locking tab of the ZIF connector in the top right corner of the motherboard.
Pull the ribbon cable out from the connector with a pair of blunt nose tweezers.
Using a Phillips #00 screwdriver, remove the four 3.6 mm screws holding down the port brackets on the right and left sides of the motherboard.
Remove the two 3.3 mm screws from the motherboard with a Phillips #00 screwdriver.
Lift up and remove the motherboard.
If your replacement motherboard does not include a CMOS battery, you may need to move it over from your old motherboard. You can follow this CMOS Battery Replacement guide if you need help!
