Zum Hauptinhalt wechseln
Logitech Signature Slim Solar+ Battery Replacement
Was du brauchst
  1. Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: Schritt 1, Bild 1 von 2 Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: Schritt 1, Bild 2 von 2
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: Schritt 2, Bild 1 von 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: Schritt 2, Bild 2 von 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: Schritt 2, Bild 3 von 3
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it. Keep it for reassembly.
  3. Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: Schritt 3, Bild 1 von 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: Schritt 3, Bild 2 von 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: Schritt 3, Bild 3 von 3
    • Repeat the procedure to remove two remaining feet along the top edge. Keep these for reassembly.
  4. Logitech Signature Slim Solar+ Battery Replacement, Remove the battery cover: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to loosen the three captive screws securing the battery cover.
  5. Logitech Signature Slim Solar+ Battery Replacement: Schritt 5, Bild 1 von 3 Logitech Signature Slim Solar+ Battery Replacement: Schritt 5, Bild 2 von 3 Logitech Signature Slim Solar+ Battery Replacement: Schritt 5, Bild 3 von 3
    • Lift and remove the battery cover.
  6. Logitech Signature Slim Solar+ Battery Replacement: Schritt 6, Bild 1 von 2 Logitech Signature Slim Solar+ Battery Replacement: Schritt 6, Bild 2 von 2
    • Use your fingers or a spudger to lift and remove the battery by its side tabs.
  7. Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: Schritt 7, Bild 1 von 3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: Schritt 7, Bild 2 von 3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: Schritt 7, Bild 3 von 3
    • Align the battery with its recess and push down firmly with your finger to click it in place.
  8. Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: Schritt 8, Bild 1 von 2 Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: Schritt 8, Bild 2 von 2
    • Lay the battery cover in place and gently press it onto the keyboard to engage the clips.
  9. Logitech Signature Slim Solar+ Battery Replacement: Schritt 9, Bild 1 von 1
    • Use a Phillips screwdriver to tighten the three captive screws securing the battery cover.
  10. Logitech Signature Slim Solar+ Battery Replacement: Schritt 10, Bild 1 von 3 Logitech Signature Slim Solar+ Battery Replacement: Schritt 10, Bild 2 von 3 Logitech Signature Slim Solar+ Battery Replacement: Schritt 10, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Tesa 61395 Tape
    $2.99
    • If you're installing new feet, remove them from their backing and firmly press them into place.
    • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
Abschluss
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Arthur Shi
327.584 Reputation
810 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 97
Insgesamt: 614
