Zum Hauptinhalt wechseln
Logitech Webcam Pro 9000 USB Connection Replacement
Was du brauchst
    1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: Schritt 1, Bild 1 von 2 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: Schritt 1, Bild 2 von 2
      • Remove the two 8 mm Phillips #0 screws on the back cover.
      • The motherboard connects the two covers together. DO NOT separate the two yet.
      • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
      Frag FixBot
      Kommentar hinzufügen
    2. Logitech Webcam Pro 9000 USB Connection Replacement: Schritt 2, Bild 1 von 2 Logitech Webcam Pro 9000 USB Connection Replacement: Schritt 2, Bild 2 von 2
      • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
      • DO NOT detach the wire connecting the motherboard to the front cover.
      Frag FixBot
    1. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: Schritt 3, Bild 1 von 2 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: Schritt 3, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Use tweezers to grasp the white wire connector on the back of the motherboard.
      • Wiggle the connector back and forth to remove it from the socket.
      Frag FixBot
    2. Logitech Webcam Pro 9000 USB Connection Replacement: Schritt 4, Bild 1 von 2 Logitech Webcam Pro 9000 USB Connection Replacement: Schritt 4, Bild 2 von 2
      • Desolder the joint on the front of the motherboard to completely detach the USB cable.
      • Follow this link to learn how to properly solder and desolder your parts.
      Frag FixBot
Abschluss
Cal Poly, Team 12-34, Amido Spring 2013 Mitglied von Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Mitglieder
65 Anleitungen geschrieben
1 Kommentar zur Anleitung
what is the connector called
Anirudh Krishnan - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 2,526
