Zum Hauptinhalt wechseln
MSI GS63VR 6RF Stealth Pro Battery Replacement
Was du brauchst
  1. MSI GS63VR 6RF Stealth Pro Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  2. MSI GS63VR 6RF Stealth Pro Battery Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  3. MSI GS63VR 6RF Stealth Pro Battery Replacement: Schritt 3, Bild 1 von 2 MSI GS63VR 6RF Stealth Pro Battery Replacement: Schritt 3, Bild 2 von 2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 weitere Personen haben diese Anleitung absolviert.
Jay Etzkorn
200 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 71
Insgesamt: 6,757
